Windchill 9.1 customized code not running on Windchill 10.1.. Java issue
  • February 13, 2013
  • 1805 views
Hi All,
I am trying to deploy the Customized code from Windchill 9.1 to Windchill 10.1.
This code is written for Exporting the Documents from Windchill.
When i try to Compile same code from Windchill shell in 10.1 version i got below Warnings and errors.
Kindly go through this and suggest the corrective actions.
The ExportDocuments.java is attched with this..
Vivek
C:\ptc\Windchill_10.1\Windchill\src\ext\util>javac ExportDocuments.java
C:\ptc\Windchill_10.1\Windchill\codebase\wt\doc\WTDocument.class: warning: Canno
t find annotation method 'superClass()' in type 'com.ptc.windchill.annotations.m
etadata.GenAsPersistable': class file for com.ptc.windchill.annotations.metadata
.GenAsPersistable not found
t find annotation method 'interfaces()' in type 'com.ptc.windchill.annotations.m
t find annotation method 'extendable()' in type 'com.ptc.windchill.annotations.m
t find annotation method 'versions()' in type 'com.ptc.windchill.annotations.met
t find annotation method 'properties()' in type 'com.ptc.windchill.annotations.m
t find annotation method 'name()' in type 'com.ptc.windchill.annotations.metadat
a.GeneratedProperty': class file for com.ptc.windchill.annotations.metadata.Gene
ratedProperty not found
t find annotation method 'type()' in type 'com.ptc.windchill.annotations.metadat
t find annotation method 'supportedAPI()' in type 'com.ptc.windchill.annotations
.metadata.GeneratedProperty'
An exception has occurred in the compiler (1.6.0_31). Please file a bug at the J
ava Developer Connection (http://java.sun.com/webapps/bugreport) after checking
the Bug Parade for duplicates. Include your program and the following diagnosti
c in your report. Thank you.
com.sun.tools.javac.code.Symbol$CompletionFailure: class file for com.ptc.windch
ill.annotations.metadata.SupportedAPI not found
add annotation.jar and annotanionProcessing.jar in your build path
