Windchill Installation - Load Balancer
  • January 30, 2014
  • 2 replies
  • 1712 views
Can anyone help on how to setup load balancer as part of windchill installation architecture defined by PTC. Please share the implementation document.
As per my understanding is we need to configure common host / configure common webserver for the master and slave nodes.
can you please share solution for above question, hope you must have worked out something by this time. 🙂
Settting up the cluster as a whole is covered by the documentation for the Windchill version in question.
Selecting a load balancer and configuring it are up to you, however. The underlying requirement is that session affinity be preserved in the load balancing.
The implicit assumption is that a hardware load balancer is used, but this is not a hard requirement.
P.S. As for setting up the cluster itself, this is much easier with Windchill 10.2 than previous releases (and somewhat different from previous releases as well as a consequence).
