Windchill Won't start - server manager?
  • May 11, 2012
  • 4 replies
  • 8856 views
We moved our windchill server to our local building. The end users consist of 2 people and we have no support staff who know how to administrate windchill.
According to the control panel, the directory services is running with no problem. It just sits on this line
INFO : wt.method.server.startup - MethodServer created - port 5003
INFO : wt.method.server.startup - Starting services - class = wt.services.Stan
dardServicesHandler
and I get this error.
ERROR : wt.manager.ServerManagerImpl - Start of MethodServer timed out.
ERROR : wt.server.manager.startup - Unable to launch 1 MethodServer instance
wt.util.WTRemoteException: Unable to get server; nested exception is:
(wt.manager.managerResource/3) wt.util.WTException: Start of MethodServe
r timed out.
at wt.manager.ServerManagerImpl.getServer(ServerManagerImpl.java:281)
at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:299
at wt.manager.StandardServerMonitor$ServerMonitor.startServers(StandardS
erverMonitor.java:332)
at wt.manager.StandardServerMonitor$ServerMonitor.run(StandardServerMoni
tor.java:212)
INFO : wt.server.manager.startup - Starting 1 additional MethodServer instance
INFO : wt.manager.ServerLauncher - Starting MethodServer
It worked before we moved and after some time (~5 mins) the method server stops and loops the same message. Do I need to change something in the config file since the IP address changed? That's the only thing I can think of.
Thanks.
Did the server hostname change or just the numeric IP address? If you changed the server hostname, then you need to follow the re-hosting procedure.
Note that by "changed the server hostname" I don't mean whether or not you changed the server from which the server is running. Rather I mean the hostname used by the software as its location, which must still be valid but which may (and generally should) refer to a DNS alias rather than a physical hostname. Also note that change from myserver.foo.com to myserver.bar.com or the like requires re-hosting.
Are you running the Windchill shell as an admin before doing a windchill start?
Aaronm8714-AlexandriteAuthor
The domain name definitely changed and i think that is the issue. How does one go about rehosting? I cannot seem to find any documentation on this. And yes I have tried running as admin.
Hi Aaron...
Did you ever get any sort of response on this? A rehost can be a major pain in the neck and the documentation is really scant. If you're still stuck on this, please write back and let us know.
Thanks!
-Brian
Hi, Aaron,
Perhaps you've already seen it, but there is a Windchill Rehost Guide available on ptc.com:
http://www.ptc.com/WCMS/files/124969/en/WCRehostGuide.pdf
Within the next month or so, this document will also be updated with information about a new rehost utility.
Jane
Jane Zupfer
VP, Windchill Publications
T 763.957.8299 E -
Thanks Jane...
I think I speak for quite a few others when I say we're waiting for this rehost utility with very high hopes!
Still running into some issues.
Initially the server was running at a remote facility. We moved it our local facility and the domain changed. The software guy did someone modifying the host file on the server and it worked.
We just recently moved into a new building where the IP scheme had changed. I went in and modified the IP in the host file to redirect the server. I can properly login and everything works on the web application. However, I cannot seem to get it to work again in Creo. It connects to the server, but then drops the connection once the login info is entered. Would the IP changing require a rehost?
We don't have any data on the server yet, but I am thinking maybe a clean install might be the right action to take here? The guy who helped do the initial install is busy and won't have time for several weeks...unless it is possible for a person of very limited server knowledge to do the install himself then I might try it.
-Aaron
