8-Gravel
October 27, 2011
Workflow Task Variables
  • October 27, 2011
  • 2 replies
  • 895 views
I am using the following code to get the ECR number and description value.
// Get the ECR Description and Number value and set to local attribute
wt.change2.WTChangeRequest2 cr = (wt.change2.WTChangeRequest2)primaryBusinessObject;
changeDescription = cr.getDescription().toString();
ecrNumber = cr.getNumber().toString();
I use these two variables in my Instructions section of the assigned task {ecrNumber} and {changeDescription}. Both of these work as expected and I see the results in the Instructions of the Windchill task and email. However, I would like to use these in the Task Name but it doesn't seem to be working. Is there more to using these variables in the Task name other than entering {ecrNumber} in the name field of the task?
James Little
CAD Admin
Corning Cable Systems
You can try adding the following to your transition:
wt.workflow.engine.WfActivity myActivity =
(wt.workflow.engine.WfActivity)self.getObject();
myActivity.setName (ecrNumber + ": " + changeDescription);
myActivity = (wt.workflow.engine.WfActivity)
wt.fc.PersistenceHelper.manager.save(myActivity);
Dax Williams
Engineering E-Tools Administrator
GE Healthcare OEC
Surgery
8-Gravel
October 31, 2011
Just to let you know, I used your suggestion below and it works great.
Thanks for the input, I would have never found this.
James Little
CAD Administrator
(817) 431-7678 - office
(817) 301-2274 - cell
Jeremiah 33:3 "Call to Me, and I will answer you, and show you great and
mighty things, which you do not know."
