SamuelBrantner
#2 EFX / AFX Tip of the Month: Automatic hole creation and screw connections
  • May 31, 2012
  • 0 replies
  • 3373 views
In this episode the definition of the powerful feature "Automatic UDF's" will be shown. With this technique you are able to give your parts a certain intelligence. The parts will then create their needed mounting holes with just a push of a button.
The 2nd topic of the video is the definition of screw connections. With this functionality you can easily add screw conncections to your assembly.
