2D TO 3D DWG
I HAVE A PART DRAWN IN 2D DXF. HOW CAN I CONVERT IT TO A 3D CREO ELEMENTS MODEL?
THANX
Paul
11-Garnet
May 12, 2014
There is a utility called AutobuildZ you can use that can help convert 2D to 3D. To enable it, set the config autobuildz_enabled to yes. There should still be a tutorial available on the PTC website.
Also, you can turn off Caps Lock when posting. Posting in all capital letters is considered screaming and it's hard on the eyes.
David R. Martin II
Senior CAD Application Specialist
Amazon
