3d dimensions in Isometeric view
  • February 23, 2010
  • 5 replies
  • 3887 views
Hi, I have a Isometeric view of a pipeline.It is assembly done without using piping module.I am unable to show 3D dimensions in the drawing. Please help. Regards Vishal
From the drawing options select allow_3d_dimensions. This is under the properties menu for the drawing.
February 24, 2010
Thanks but unable to show. please help Regards Vishal
I am also trying to add dimensions to an isometric view of a simple cube. I have allow_3d_dimensions applied. I can pick edges and drop dimentions as usual, but they are not right. When you try to drop the dimention, you can select vertical, horizontal, parrallel for example. But if you select vertical, it gives you the vertical dimention of the isometric line. One edge of the cube is 200mm long, I just want to drop a 3d dimension which shows 200mm. The only one I can drop are stupid irrelevant dimensions.
