3D Model Sketch Line Weight in Drawing
Is there any way to change the line weights of a sketch made in a .prt or .asm when you print out the .drw it's used in?
The pen tables don't do anything, the the line style can change the color, but doesn't seem to do anything about weight, changing the options in the 3D cad app doesn't seem to propogate the change to the PDF.  Any ideas?
Thanks!
I'm on creo 9
pentable works well ... see below mentioned lines
!*** Sketch feature
pen 7 thickness 0.015 cm; color 0.0 0.0 0.0; section_color
!*** other curves
pen 8 thickness 0.035 cm; color 0.0 0.0 0.0; curve_color
Note: Drawing view must not be displayed in Shaded mode.
!*** Sketch feature
!*** other curves
Thank you!  I didn't realize the view couldn't be shaded.
