3-Newcomer
Nov 4, 2026 7:14 PM UTC
3D Part Dimension Not Display
I open a part model in Creo 10 and double click on the model, but the dimensions are not displayed. Creo 7 is able to display the dimension on the same part number. I am not sure why and still cannot get it displayed.
    StephenW
    Nov 5, 2026 4:05 PM UTC
    I get that on occassion, I don’t know why. Sometimes seems to be part dependent. Normally it just works as it always has.
    Nov 6, 2026 8:55 AM UTC
    This is an unexpected behavior indeed.
    Can you confirm both config.pro files are identical ?
    If they are, do you mind creating a simple Creo 7.0 part and attaching it ?
    mung3-NewcomerAuthor
    3-Newcomer
    Nov 6, 2026 2:00 PM UTC
    Thank you all for response. I only have this problem when existing parts are pulled up. New part names have no problem. Config.pro files seems to be alright.
    Nov 13, 2026 5:08 PM UTC
    if it affects only olden part that you pull up then you might want to try the Detail option update_solid all and run the Model Player
    Nov 23, 2026 5:41 PM UTC
    On one of the older parts in Creo 10, could you select a feature with a known dimension in the Model Tree and choose Edit? Do the dimensions appear that way? If they show from the Model Tree, I’d select that same feature in the graphics window and compare. If they’re missing both ways, could you share a simple sample part that shows the same behavior and your exact Creo 10 build?
