Absolute Drawing dimensions for Offset Csys Points
- 5 replies
- 3577 views
- Translate All
I have a model that I've created a number of points using the Offset Coordinate System Datum Point. To position the location of the points correctly some needed to have negative values in the X, Y, and/or Z direction.
Is there a way (without Overriding the dimension) to show all the values as positive?
