activate copy geometry in Creo3
I have the standard version of Creo3 M050 and i can't use the copy geometry and publish geometry options (it's gray)
Do I have to activate them in the config.pro? If yes how?
Do i need a additional licens for this?
actual licens are:
4DNavigator, AE, Assyperformance, CDT, Data_for_PDGS, Detail, Design_Animation, Ecad, feature, flexible_modeling
Thank you for your help 🙂
SanathAnswer
@amazingwaldi, you need Advanced Assembly Extension license or  Pro/ASSEMBLY license module to access COPY geometry feature. Check if you have this Extension/ Module in your license file. If yes then you need to reconfigure the application to look for this license. If not then contact PTC sales to get the required license.
Steps to reconfigure Creo if you have the license is listed in the below link
https://www.ptc.com/en/support/article/CS60577
Unfortunately, I think you need additional licence.
Il really don't understand why it's not part of the basic licence as, for me, it's a core feature. 🤔
Thank you @RaphMORIN for your help 🙂
Sanath16-PearlAnswer
Thank you @Sanath for your help 🙂
