add a new feature in sketch: C2 round.
If you can add C2 round in sketch, it would be huge improvement to make the A class surface.
In WF4 if you have, for example two splines in sketch and then you create a fillet between them, you get the T sign for the tangent constraint, if you then apply an 'Equal' type constraint to the spline and the round you get a C sign for equal curvature between spline and arc (I assume this is still the same in Creo)
Or did you want something more than this??
That is an excellent tip, Charlotte. Never knew that. It does still work in Creo 2.0.
Welcome to the forum, Gang Hong.
