Add an external assembly to a family table
Hi everyone, im working with some assemblies that each of them has been created independently. My question is, can i add several external assemblies to a family table? or i have to create again each and everyone of them from the biggening from a main assembly?
Thanks for helping me out. Best regard.
Dale_Rosema
If I understand correctly, you are wanting to attach some sub-assemblies to an assembly and have them part of a family table. When adding a component, you select the subassembly.
The constraints need to be independent from each other. If not, some assemblies will only appear when the subassembly to which they are constrained is present in the model.
Some will caution about using subassemblies with family tables call out in another family tables. It all depends on how complicated your parts are. I work frequently with family tables within family tables within family tables.
Community Moderator
Hi @OY_10733010,
Anurag
