add pos_nr to the same part in an assembly
- 5 replies
- 1278 views
- Translate All
To all,
I am looking for a way to assign, in an assembly, the same pos_nr needed in GPLM / WindChill, for BOM structures, without needing to do it each time for the same component. In the images below, I would need to pick in the pos_nr column for each one, change to Integer, give the value and then designate them. I am looking for a way that I can easily add it to all of them at the same time. We are finding it time consuming to have to do each one individually.
Any help is appreciated.
Dennis J Rehmer
ABB
