Adding a Marker in Cable Assembly - Creo Parametric
I am attempting to add a marker on a pre-defined cable assembly. The part is in assembly mode, and I am unable to open the cable assembly separately. I see online that I am supposed to use a marker.
To Apply Marker to a Cable
1.Click Cosmetics > Marker.
The Marker tab opens.
2.Select a segment of the marker.
3.To accept the default length, diameter and thickness click the check mark.
4.The marker is created with the default values and the tab is closed automatically.
I cannot find the 'cosmetics' icon to create the marker while in assembly mode. Can anyone help direct me?
I figured it out myself. For anyone in need:
1. Click on 'Applications'
2. Click the 'Cabling' icon. Cabling tab opens.
3. Under 'Cosmetics' there is a small blue emblem called 'Marker'. Click this and apply the marker to needed cabling.
CW_104321471-VisitorAuthorAnswer
