Adding a Thumbnail Image to the Bill of Materials in 3D
Hello everyone,
I've succeeded in customizing my bill of materials in Creo 3D. The only thing I still need to do is add a thumbnail image for each component. This is a requirement from my client, who doesn't want to look at the part's manufacturing drawing; instead, he wants the BOM to be exported directly from 3D.
So my question is:
1. How can I add an image to the thumbnail in one of the columns?
2. How can I have it also include the component’s position within the assembly?
Right now, the .fmt file looks like this:
.breakdown
%$type %$name contains the following:
.titles Qty; Name; Material; Mass [kg]; Thickness; Ptc_common_name;
.row %$quantity[-4d];%$name[-20.20s];%PTC_REPORTED_MATERIAL[-15.15s];%PRO_MP_MASS[-10.3f];%SMT_THICKNESS[-6.1d]; %PTC_COMMON_NAME[-15.15s]
Oh, and one more very importante thing: how do I prevent the following parameters—which I no longer need—from appearing in the red box when exporting?
Thanks in advance!
Catalina
Community Manager
Hi ​@BD_9134744
Thank you for your question. 
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Catalina | PTC Community Manager
Mahesh_Sharma
22-Sapphire I
Hi ​@BD_9134744
Customization of the Bill of Materials (BOM) is limited to displaying parameter-based information and outputting the values of user-defined parameters. Options such as adding thumbnail images, removing the Actions column, or displaying component position information are not supported through BOM customization. As the customization framework is designed to present parameter values only, these requirements are not currently available.
I hope this will help.
Thanks.
Considering your requirement and thinking out of the box, if one may consider the Assembly Model Tree as a BOM, a *.pvz should satisfy the customer’s requirements. A *.pvz file can also have model annotations, Notes etc. When one clicks (selects) on any item in the model tree, the item would be highlighted in the graphics window. One can even zoom to the selected component e.g. a small washer in a large assembly.
This would not need any customization. The only hitch it would not be a BOM with Quantity but a Model Tree with instances of parts.
I am still on Creo 10.0.9.0. Hence, would not be able to say how it is addressed in later versions. I believe, in the later versions, one can have a BOM table on the Graphics screen itself.
*.pvz can be opened from Creo View Express, which is Free to download and use from PTC’s site. The customer can use that app.
Knowing, what we know is just a fistful of Earth, brings in humility.
