adding restricted parameters by Modelcheck
I want to know if it's possible to add (restricted) parameters from the document.lst by running Modelcheck.
Adding mannual restricted parameters in the parameters-window is possible, yet. But when I want to run modelcheck to check the parameters, that were defined by company, I doubt if its possible!? Just adding a normal parameter by running modelcheck also works.
The help gives me some options like >/<, pdm, wildcards and also list. The last can be an option, but then we working with more list(defined by document.lst and list defined in modelcheck).
Greets Raymond
