Adding Stiffness to the flexible solid cable.
In automobile, oil industry solid flexible metallic pipes/cables are used. We have stiffness value of each cable and have a fix length. There are some intermediate points where cable have clamping. Now while modelling the cable, I have to create a model of cable considering the stiffness (which can be directly related with bending radius). So my concern is that, Is there any to add stiffness value in cable or is there any way to construct the model in present case where routing is critical.
