Additional Tapped Hole sizes
By default, the UN Hole Sizes in Creo 10 go up to 1½ - 6.  We deal with larger holes quite often.  How can this be changed so that UN Hole Size options are available up to 2 ½?
Thank you!
tbraxton
tbraxtonAnswer
The default stored location of the hole files is <Creo Parametric loadpoint>\Common Files\text\hole
Refer to this link for an overview of adding custom hole files.
https://www.ptc.com/en/support/article/CS31227?&as=1#LOCATION
The files behind the threaded hole structure are just text files that can be user modified. Where I used to work, we modified the file it used for tap drill sizes that our shop used.
Hi adding up to ​@BenLoosli’s reply, i recommend that you backed up existing files and edit existing ones iteratively.
There is no “debugging” tool so have a troubleshooting method, make one change at a time and arm yourself with patience.
razmosis14-AlexandriteAuthor
Its a little ridiculous that the thread sizes stop at 1 1/2-6 UN.  That only accounts for ¾ of the bolt sizes where I work.
Can someone tell me what the text file is named and where it is located?
Thank you.
