SamuelBrantner
Advanced Framework T-slotted profile library demands
Hi Community,
we are currently thinking about adding some more t-slotted profiles to the advanced framework extension and are wondering what you are using in you designs.
Currently we offer the following manufacturers:
  • Bosch
  • Item
  • Kanya
  • Maytec
  • Minitec
  • Rose+Krieger
  • Frameworld INCH
  • 8020 INCH
  • Controlled Dynamics
Do you miss anything in this list and also if you are using the mentioned libraries already are there profiles missing that you would like to have in a future release?
Any feedback is welcome.
Greetings Sam
These manufacture is common in South East Asia. Detail As below;
1. SUS Incorporation.  https://global.sus.co.jp/
2. Nic Incorporation. www.nic-inc.co.jp/english/alfaframe/
3. Misumi Group Incorporation. Aluminum Frame 8 Series/slot width 10/40x40mm | MISUMI | MISUMI Thailand (misumi-ec.com)
Misumi T Slot
SUS T slot
NIC T Slot
SamuelBrantner
@JA_9796064 ,
Thanks for your feedback.
Can you also post sources for the desired manufacturers?
Greetings Sam
Greetings Sam
6-Contributor
Mcmaster-Carr
Automation Direct
Patriot_1776
I've always used 80/20, we use it here, and I've never even heard of the others.  If you do it, you ABSOLUTELY have to make sure it's correct.
6-Contributor
8020 Metric - Series 20, 30, 40, 45
