After changing from Creo 7 to Creo 11 started doing fix_params.log
Hello, which configuration option restrict creo from doing it's fixing parameters for now our designers have around 200-300 errors/warnings in models due to this issue. fixing it by hand is impossible
Deleted parameters in model KM011360:
PTC_MODIFIED
PTC_MODIFIED
Deleted parameters in model 00005675:
PTC_WM_NUMBER
PTC_WM_PART_NAME
PTC_WM_PART_NUMBER
MC_VERIFIED
Deleted parameters in model 00005676:
PTC_WM_NUMBER
PTC_WM_PART_NAME
PTC_WM_PART_NUMBER
MC_VERIFIED
Deleted parameters in model 00602968:
PTC_MODIFIED
PTC_MODIFIED
Deleted parameters in model 00602967:
PTC_MODIFIED
PTC_MODIFIED
PTC_MODIFIED
After contacting support we've declared that this problem is propageted from Windchill.
Parameters was changed in PDM (Windchill) and they were not changed in CAD Documents(*.prt, *.asm). So when creo tries to open it it immediatly tries to chnage those parameters.
please contact directly PTC Support.
It looks like the standard PTC parameters are not being located by ModelCheck when being processed. These should be locked so as to not allow them to be deleted. In some cases, the PTC_WM* parameters are not in the file before it has been saved. Have these parts been saved in Creo 10 before the ModelCheck was run against them?
ilyachaban16-PearlAuthorAnswer
