AFX vs Student Edition
I'm teaching myself Creo with version 6.0 student edition.
In trying to work on the framework utility, the system reports that the library parts ( standard beams and the such) were created in a commercial version of Creo and therefore, they are not compatible with the student version.
Is there a way to get around this limitation with a compatible library or even with home-made components that will effectively be compatible with the student version?
Thanks in advance.
SamuelBrantner
Hi @MilongueroViejo
we've recently added support for student version. Please make sure to use Creo 6.0.5.0 with AFX 6.0.5.0.
Hope that helps.
Greetings Sam
Greetings Sam
Hello there and thanks for the prompt reply.
I have the right version of Creo ( 6.0.5.0) but the AFX version is 6.0.2.0 Lite.
Is there a way to update the AFX only?
Thanks in advance.
SamuelBrantner
Hi @MilongueroViejo
you should have the 6.0.5.0 version in the following folder:
PTC/Creo 6.0.5.0/Common Files/afx
How do you start AFX? Usually if you use the embedded version of Creo then you always have the latest build.
Greetings Sam
Greetings Sam
