6-Contributor
AFX- Where will BUW_NAME (Creo 12.4.0.0) translated?
we are using Creo 12.4.0.0. Scince this version we have a problem that the BUW_NAME from profiles (Aluminium) will translated from the German Profil to Profile.
How can we prevent/correct this?
Thanks for your help.
Regards
Ute
SamuelBrantner
Hi @vhoedl ,
you can copy the file from the attachement to the following directory, that should fix the issue:
C:\Program Files\PTC\Creo 12.4.0.0\Common Files\afx\text\german
This has already been reported to PTC and will hopefully be fixed in one of the next Creo builds.
Greetings Sam
Greetings Sam
I hope @SamuelBrantner  will help you
SamuelBrantner
Hi @vhoedl ,
Greetings Sam
Greetings Sam
