Aug 20, 2011 9:22 AM UTC
Again about inserting image in drawing
Good morning/afternoon,
the only way that i can insert picture in drawing in Creo (Windows 7) is:
Layout->Insert->Object->Create New->Paintbrush picture
After that i copy&paste the image i create outside. The size of the picture is different from default 189x189 of Paintbrush, but when i click save and exit image size is not the same of the image i copied&pasted.
Anyone can help me?
Thanks.
Aug 22, 2011 7:20 PM UTC
Hi Mauro,
You can insert picture without creating it the way you described. Basicly you need to open picture you want to insert in drawing in some program.
Example: photoshop file you open in photoshop and then you try to insert it in drw or bmp/jpg in windows paint and then try insert in drw.
I have no idea why Creo/Proe needs to have some program to be able to insert picture.
Hi Mauro,
Aug 25, 2011 6:30 PM UTC
Mauro,
Did you try Layout->Insert->Object->Create From File (instead of Create New)? It worked for me. All I had to do was to browse to the image. But yes you might wanna open it first in an image viewer.
Mar 26, 2013 11:26 PM UTC
Vote up this Idea so PTC fixes this issue:
http://communities.ptc.com/ideas/1761#comment-6929
Jun 14, 2013 6:40 AM UTC
the easiest way to draw images c# is to open image in some programme, and then insert imaget to the place you want it to be.
18-Opal
Oct 20, 2015 2:59 PM UTC
Hi Mauro,
If one of the responses helped resolve your issue, would you please mark it as the Correct Answer?  That way other users visiting the discussion will know; as the correct answer gets copied right below the question.
Amit
Nov 27, 2017 11:18 AM UTC
https://youtu.be/DMYYaDJ1Azc.. I DID THE SAME...it is working fine...
