Apr 16, 2013 10:38 PM UTC
Allowable dimension values?
Hi folks,
I'm stumped on a question from a co-worker.
Is there a way to limit a dimension value to increments of 1, e.g., 5.62, 6.62, 7.62..., etc.?
User wants to select a drag handle and it snaps to the next available dimension value.
-Josh
Apr 16, 2013 11:22 PM UTC
There are a few ways to limit values. The method is application dependent.
The 1st that comes to mind is dragging components that have assembly constraints. These will have degrees of freedom within their specified constraint limits.
Second is the ability to use "if" statements in relations where you can have set allowable or ranges of valid values.
If you have an "if/then" type of evaluation, you can use a graph feature drive your relation. If X=n then Y=value of graph.
If you have a better idea of exactly your coworker is trying to accomplish, we can dive deeper into any of these.
JoshH1-VisitorAuthor
Apr 17, 2013 12:10 AM UTC
The application is a simple part extrusion.
This is basically what I'm after, but don't know how to write the logic without Creo spitting it back.
IF(D367>=9) AND IF(D367<=10)
D367=9.84
ENDIF
IF(D367>=10) AND IF(D367<=11)
D367=10.84
ENDIF
Apr 17, 2013 12:47 AM UTC
if statements are nested.
if d367<=9
if d367>=10
d367=9.84
endif
endif
... then the same for the second test.
You also need an else statement if neither work.
I am not at the system at the moment or I would get the exact syntax
