Sep 15, 2022 7:50 AM UTC
annotate on cylinder surface failure
I am using Creo Parametric Release 4.0 and DatecodeM150
Creo 4.0 M150 could not annotate on cylinder surface , even the selection pass, dimension won't be generated
while same action on Creo 4.0 M110 is passed
Here are the errors that I faced
no error but just return that the selection is invalid and can not continue
Sep 21, 2022 1:34 PM UTC
@IZ_8255117 wrote:
... Here are the errors that I faced
no error but just return that the selection is invalid and can not continue...
Could you please provide a screenshot of this warning?
Sep 23, 2022 7:26 AM UTC
see above please, select surface, can not continue
