Patriot_1776
Sep 29, 2016 1:34 PM UTC
Any tips for creating a VSS (Variable Section Sweep) in creo 3?
I can pick other trajectories besides the origin trajectory all I want, but the section will not be driven by them.  I can create the old style swept blend, but that's it.  It's forcing me to make 2 sections, and then it gives me a simple blend between the 2, but I should be able to use only one section, and drive it by other trajectories (like a VSS), and I can't.  Am I missing something?  I thought the VSS was now bundled into the swept blend command???
Any help would be appreciated.
Thanks!
Patriot_1776
Sep 29, 2016 1:57 PM UTC
Ok, figured it out, it's NOT in the swept blend, it's in the sweep, and you have to check a stupid icon to get it to work, instead of simply looking for a WORD to describe it.
Is it cheating to mark myself as having the correct answer?
Patriot_1776
Patriot_177622-Sapphire IIAuthorAnswer
Sep 29, 2016 2:11 PM UTC
in CR2 you have to click highlighted button when creating VSS.
MH
Patriot_1776
Sep 29, 2016 5:06 PM UTC
Yup, another retarded indecipherable icon to try and figure out.....  To me, that's a welding symbol.......
2-Explorer
Sep 30, 2016 12:08 AM UTC
It's a happy icon.
