Anyone get real fancy with part parameters and relations?
Hi guys,
Lets say i have a part file called: N12345-2000.prt
It is stored as a parameter called rel_model_name
I would like to take this parameter, and remove the first 7 characters of the name.
So I could now have this new parameter (lets call it "detail") which would just be 2000 in my parameters.
Is this possible?
Jay
BenLoosliAnswer
If it is always 7 characters before your substring, it is easy.
Detail = extract (rel_model_name,8,11)
If the number of characters varies, then you get into using the fndstr function to search the rel_model_name for your '-', which will return the start position for the extract command.
stpos = fndstr(rel_model_name,'-')
detail = extract(rel_model_name, fndstr+1,fndstr+5) assuming the detail part is always 4 characters.
If that changes, too, then there is the strlen function to get the total length.
endpos = strlen(rel_model_name)
detail = extract(rel_model_name, fndstr+1,endpos)
TomU
Edit:
Sorry, I misread your question.  Yes, as @StephenW explained, this is pretty straight forward to do.
StephenW
In the relations, use the Extract command to get what you want from the existing parameter.
I think this post has some good examples.
https://community.ptc.com/t5/Part-Modeling/EXTRACT-relations-function/m-p/577971
BenLoosli23-Emerald IIIAnswer
Yes! this is exactly what I needed.
I added a simple line:
detail = extract(rel_model_name,8,4) to get what i needed in the detail field.
Thanks for all the help guys!
Jay
Chris3
Be aware that if you try and extract more characters than are in the string (ie you have parts that don't follow the same naming scheme) it will return a Null and you will get nothing. For this reason you might want to check the length first.
