assembling correct hardware to matching female threaded part
Is there a way in Pro/E to provide/force to assemble the right screw to a sepcific bolt pad (riser).
For example basically I want to be able to assemble only M10 bolt on a M10 female threaded part. Is there an intelligent way in Pro/E forcing the designer to pick up the correct size of screw? May be a warning message is wrong size of a hardware is picked up against a mating thread.
