Assembly mirror
I am using Creo Parametric 8.0 8.0.1.0
Is it possible to mirror the assembly along with the motion constraint from it.
The solution has been given by PTC that need to uncheck the placement dependent checkbox.
tbraxton
It is possible to mirror an assembly. If you are in Creo 4 or newer, use File - Save As - Save a Mirror Assembly. I am not positive of the behavior of mechanism constraints in this context but they should be easily verified.
kamleshjoshi15-MoonstoneAuthorAnswer
