Assembly model scale
I would like to change the model scale of a whole assembly (Creo2)
Model \ Operations \ scale Model
> entering a scale value (1.5)
> confirmation (Yes)
This don't have any effect. So we have to change scale part after part.
Then, if this operation is not possible on an assembly, strange to see this option is available in assembly mode.
Is there any manner to do this ?
StephenW
StephenWAnswer
Don't use that scale. It will only work part by part.
You may be able to use a UNITS change to accomplish this.
Go to file, prepare, model properties and adjust the units, if you can set the units change to accommodate your needed scale.
First unit change would be to "interpret" the dimensions (1" becomes 1.5 units).
Second unit change would be back to the "convert" back to the desired units (1.5 units becomes 1.5")
I just don't know if you can make it work for any scale factor or if it has to be only a real units change, which wouldn't work for you.
I know it's not a good explanation but you might want to experiment with it to see if you can get something to work.
kdirth
The option in the assembly would control dimensions created at the assembly level such as offset datums, assembly constraints, and assembly cuts.
StephenW
StephenW23-Emerald IIIAnswer
I can manage scales as I wanted according to your explanations.
However, there are 2 steps for doing this.
1 In Units tab : Creating a user unit ex: 1 my_unit = 1.05 mm
2 In System of units : creating a custum SU with the special unit I've created.
