Sep 25, 2012 7:35 PM UTC
Assembly rounds?
Good afternoon, All:
I have a part that will go through two stages of machining: the first will
be a blank for waterjet; the second will add blind cuts. To do this, I've
made the waterjet blank, assembled it into a new blank assembly, and made my
blind cuts. I would like to put a round at the inside edges of the cuts
where they meet the next surface, so I go to Cut & Surface>Engineering>Auto
Round> Round. But nothing highlights as I mouse over the model, and I can't
pick any edges or surfaces to reference for the round.
Can anyone tell me what I'm missing? Is there a configuration option I need
to set?
Creo 2.0 M010/Windchill 10
Carol
efefefefefefef
Applied Research Labs
University of Texas at Austin
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
cfly1-VisitorAuthor
Sep 25, 2012 9:20 PM UTC
This was apparently meant for me, not Rui.
By using the waterjet blank as the only component of an assembly, I, too,
have only two files to be controlled, and the blank is automatically brought
in when the assembly is opened as the base part to cut; this is how we do
all of our "altered items." The only reason this is a problem is because I
cannot add a round to an assembly; it has to be a swept feature. But I feel
the round functionality should be available in assemblies because there are
many times that a cut might be made after assembly (particularly in a
weldment) that would be created with a ball end mill, and therefore, the
round would be there - in reality, it would not be adding material, even
though it does that in the file when the operation has to be done with two
features.
Either way, it's not my call to change our policy.
efefefefefefef
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
Sep 26, 2012 7:41 AM UTC
Carol,
Could you create your cuts as surfaces (quilts) first; round the quilts;
then solidify as cuts?
Particularly for ball-ended cutter features, and milled pockets which
break out through complex geometry, this technique can be more stable in
any case.
Jonathan
Sep 26, 2012 12:15 PM UTC
In Reply to Carol Fly:
Yeah, I'm not apt to use that approach either, as family tables are frowned
upon for this kind of thing. We, too, have been burned by them.
How are family tables bad for this kind of thing? It would have been the first thing I would have suggested:
Make the generic the final version of the part after machining is complete. Make an instance called "filename_waterjet" or something like that and suppress the rounds. You can now put these two instances into one (or two drawings if you are so inclined). The easiest example of where something like this occurs is with sheet metal parts. The blanking is done on one machine, then the forming is performed on another. Both of these instances appear on our drawings and are used to make the final part.
How do family tables burn you? I'm not sure why it wouldn't be the most robust way to deal with this. It was also mentioned that Creo's method of treating an entire family table as one file would revise all instances. We have always updated all of our instances at the same time like this, and besides it being potentially inconvenient for certain people/companies (having to potentially update physicaldrawings on the floor) I'm not sure why this would be a problem either?
cfly1-VisitorAuthor
Sep 26, 2012 2:22 PM UTC
That's a thought; I'll have to try that next time I have something like
this. Thanks!
efefefefefefef
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
cfly1-VisitorAuthor
Sep 26, 2012 2:32 PM UTC
The problems happened before I came here and for a little while after,
before I was up to speed on things, so I didn't experience them and don't
know the details. Honestly, they might have been exclusive to family tabled
*assemblies*, but I'm not sure. The rule here has been to avoid them when
you can except for library parts, so I do, and the single component assembly
with assembly level cuts is the way we've been told to do altered items, so
that's what I did. That's all I can tell you; perhaps someone else from our
organization can elaborate...
efefefefefefef
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
Sep 26, 2012 3:12 PM UTC
We use family tables for our processed parts (like bent brackets, etc.). They do work well in many instances, but if you use Windchill or any type of promotion process to control your parts, you have to have the change process defined to make sure that all of the instances are revised (changed) at the same time. If you don't you will run into issues on the backend of the storage (check in issues, etc.)
Just a thought on family tables from the administration side of things.
John Bennett
Cad Business Administrator
(801)513-9001
[Lifetime_Logo_BlkWhite_Sans_email sig]
2-Explorer
Sep 27, 2012 9:12 AM UTC
My solution would be to create the cut geometry in the assy as a surface
quilt (including rounds) and then cut>use quilt (solidify).
Sep 29, 2012 9:15 PM UTC
This is a perfect application for inheritance features, IMHO.
First, design your finished part. Be certain to model it such that the interim steps appear in the proper sequence during the part history.
Next, create a model for your 2nd manufacturing process; inherit the finished part geometry into it. Edit the inheritance feature, and suppress the blind cut features created by the 2nd process - et Voila, you will have your post-waterjet part!
Copy this part - it will become the model for the initial waterjet blank. Edit the inheritance feature; supress the waterjet cuts - and you should now be left with your blank part.
I don't think that this will cause you any Windchill or Creo-related grief, since no Family Tables were harmed during the making of these models!
Good Luck and let us know if it works...
to set?
Sep 30, 2012 8:43 PM UTC
Hi Folks,
I endorse Mark's proposed methodology. Of course in ProE there are
numerous ways to achieve the same looking result so to me it boils down to
robustness and I think Mark's method is the gold standard.
Sure you could do it all in one model with family Tables and for simple
stuff this can be robust however it can spin out of control if you get
variants or change in design.
Personally I do not think assembly cuts are a robust methodology and we
don't use them for that reason but in the end nothing is right or wrong.
One caveat in my comments is that we still don't yet have PDM with the
additional complications which that can cause but I wonder which of the
three approaches is most robustly handled in Windchill? I saw a very good
presentation back at the 2007 conference by Kevin Anderson and Craig
Iverson (Of Fluidmaster) on using Inheritance Features versus Family Tables
for use in Windchill and I was convinced. I can find a PDF of that
presentation if people are interested.
*Brent Drysdale*
*Senior Design Engineer*
Tait Communications
