attribute in relation
hello, everyone, do you know how to set the parameter's attributes in relations?
such as, I'm using repeat table(the attribute is recursive) and I want to set some assembly(very many,100 pieces)'s attributes as flat, so I want to use relation to set these assembly's attributes as flat. but I don't know how to set them
Please specify what software you mean?
jason1111-VisitorAuthor
It's Creo parametric.
It would depend on what parameter you want to use.
Repeat region only parameters, like index, are not available outside the repeat region table.
Please give an example of the type of parameter you want to extract and what you want to do with it.
