7-Bedrock
December 1, 2019
Auto change value up to Document Type/subtype
I want to customize the one of the frame cells up to document type in drawing. I've looked up a parameter for subtype but I couldn't find. Changing of title isn't very important, I can define as "Dimensions" for all of them.
If document type is Assembly then:
Title: Dimensions,      Value:   blank or "---"
If document type is sheetmetal then:
Title: Unbend Dimension       Value: Unbended bounding box
If document type is part then:
Title: Dimensions            Value: Bounding box
Best regards,
