3-Newcomer
Auto Creation of family table instances drawing
Hi Everyone,
I wanted to know if there is any functionality in Creo to automatically generate drawings similar to how Family Tables automatically generate part or assembly instances.
For example:
  • If we have multiple variants created using a Family Table,
  • Can Creo automatically create corresponding drawing files for each instance?
  • Is there any built-in option, mapkey, automation, or any related approach available for this?
Any suggestions or best practices would be helpful.
Thanks!
As of Creo 10, the standard way to make separate drawings for each instance:
  • Create a drawing of a Family Table instance or generic that contains the most features. Add views, dimensions, notes, etc. that you want on the other drawings.
  • Save drawing
  • Use Creo’s Drawing Models > Replace > Select Instance for new drawing. The views, dimensions, notes, etc. are transferred to the new instance.
  • Adjust drawing as needed for new FT instance (move views, change notes, delete broken dimensions, etc.).
  • File > Save As > Save a Copy with new name (presumably the name of the instance).
  • Repeat. You may want to start again from the first/original drawing if you had to delete items (ex: dimensions).
You could create a mapkey to speed parts of this up. This could probably be automated using Creo’s API’s (VB, Toolkit, etc.).
I think most people would say don’t keep a drawing for the generic when you have drawings for the instances, but follow your company standards/best practices.
