3-Newcomer
Automation/ Parametric Options Creo
I am using Creo Parametric Release 7.0 and Datecode7.0.7.0 I am attempting to automate the Fix Indexing process in a Creo drawing for multiple components within an assembly by assigning RPT_INDEX values through relations at the assembly level. The goal is to update the BOM item numbering and sequence automatically in a single operation. for Here are the errors that I faced after assigning and verifying the relations, the BOM table does not rearrange according to the specified RPT_INDEX sequence upon regeneration. Additionally, the RPT_INDEX values are not consistently reflected against the intended part numbers, resulting in incorrect item sequencing within the BOM. We would like to understand whether this behavior is due to a Creo limitation, configuration requirement, or software issue, and seek guidance on achieving fully automated Fix Indexing through relations.
Hi
Could you please elaborate on this? By Sequence, do you mean Assembly sequence?
For any automation to happen, rules need to be defined. Can you share those relations along with screenshots.
This would help to understand the context better.
Knowing, what we know is just a fistful of Earth, brings in humility.
