Autoscaling is not performing as expected, while importing dxf file.
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
We having an issue on Creo detailing while importing dxf file, autoscaling is not performing within the sheet size.
Any idea about this, please let me know
kdirth
Can you provide more information on what you are doing, how you are doing it and what is expected.
In Creo 7, when I import a DXF into a drawing, I am asked if I want to "Scale to fit format?"  If I select Yes, the dxf Is scaled to fit the sheet size.
