Batch migration from Solidworks to Creo parametric
Hello All,
I want information related to convert large amount of files approx 5000 to 10000 files from Solidworks to Creo Parametric.
What will be the best option to do this? May be any batch migration tool or add in?
Thank you.
Article - "How to convert Solidworks data into Creo format with Creo distributed batch applying a template at the same time": https://www.ptc.com/en/support/article/CS306921
There are numerous consulting companies that can do this for you.  Also, depending on your needs, there are solutions that will translate your CAD data and keep the "design intent", i.e., the translated copy will stay as a feature-based product.  See for example, software from Elysium
