3-Newcomer
Sep 21, 2022 12:38 PM UTC
Batch step import
I am using Creo Parametric Release 7.0 and Datecode7.0.3.0
I am having an issue with the ptcdbatch.bat: some of the parts that get created using the batch script are not added to the PCBA when I import the emn and emp files.
I don't have that issue if I manually import the step files into Creo.
Note: that I am using the same config.pro file in both cases.
tbraxton
Sep 21, 2022 12:40 PM UTC
Are you using a hint map file? That can affect the how components import.
3-Newcomer
Sep 21, 2022 12:43 PM UTC
Yes, I am using the same hint map file in both cases.
tbraxton
Sep 21, 2022 12:59 PM UTC
The part is created but not placed in the assembly when using batch mode? I would check the component ecad origin csys and verify ECAD/MCAD naming parameters as a start. Compare the models (batch vs. manual) using the model compare function in Creo if you cannot spot anything upon inspection.
Some more detail will likely be needed for anyone here to help on this. Are there any special characters or spaces in any of the component names that are problematic? Are the same import filters applied in both scenarios? Are  IDF specs matched for export from ECAD side to one supported by Creo? Last I checked Creo does not support IDF 4.0 so verify IDF version support on both ends.
