Best way to copy sketch to new part?
  • September 9, 2011
  • 4 replies
  • 22911 views
I've been wondering what the best way to copy a sketch from an old part to a new part is. I've had situations in the past where I wanted to copy a sketch of a detailed hole layout to another part and I've tried using a simple copy and paste but it doesn't keep all the dimensions exactly like the old sketch had. For example, I had a control panel layed out and one of the engineers wanted to add some holes to it for more components. Well, the panel I had layed out wasn't big enough to have the extra holes added to it while still being asthetically pleasing. So, I had to make a bigger panel and copy the sketch over to it. When I did this, it left out all the "strong" dimensions I had put into it plus many other little things which ended up costing me a lot of extra time to get it back into shape. Is there a better way to do this? If so, please let me know how I should do this. Your input is much appreciated.
Sam Lamb
Best answer by SM_9292819
Hey Sam,
Here's another idea for copying sketches, and it enables you to store the sketch for easy use at any time. You can use the Sketch Palette. Here's a link to a video tutorial:
http://learningexchange.ptc.com/tutorial/198/increase-sketch-productivity-with-sketch-palette
Let me know if this helps.
Use copy and then start new part and then paste special
Hi Sam
I use a different way to copy ; But I can not say that it is the best practice
What I do to copy a sketch with large nos. of entities
1. Make ceterlines on the reference planes.
2. remove the default reference planes
3. Make the centerlines horizntal and vertical respectively
4. Make all the dimensions strong with reference to centerlines
Now all the entities are free from the plane reference
Then I copy and paste the sketches
this process helped me many times
Hope this would help you too
Hey Sam,
SamLamb1-VisitorAuthor
Steven,
Thanks, that method worked great. It seems to be the most organized way of doing it. One question I have is: What is the best way to accurately locate the old sketch onto the new part? My guess would be to use a point located in the exact center of the old sketch and also have a point on the new sketch that I can use to attach the old sketch to.
