Best way to import STL or OBJ files
Is there a best way to import STL or OBJ files (mainly used for 3D printing) in CREO Parametric?
I was not able to get parts with a smooth finish by using the OPEN function, those little triangles do not translate well to a nice finished surface, they look really ugly and blocky after I export/save them using the Shrinkwrap option.
Even on level 10 for Shrinkwrap they still look awful in the end! Wish they had level 100 in there...
Is there a better way to obtain a CREO part starting with an STL or OBJ file?
Thank you!
(I really hope I chose the correct location for this message)
Hi @cgherghe-2
Have you tried Freesyle Reconstruction on the imported model?
To Reconstruct Shapes from Facets
-Thanks
Hi @cgherghe-2
-Thanks
No, I do not know how to use that feature...
Any tutorials out there that you might be able to recommend?
YouTube or PDFs, I will go through them!
Many thanks!!!
Hi @cgherghe-2
Try this link https://youtu.be/Rh0SfwHj9Kk?si=aDuZEsBhCQoMQp9z&t=137
-Thanks
