BID Question
  • July 9, 2013
  • 2 replies
  • 1463 views
Hi, I replied to direct email I believe. Sorry for the confusion.
    John,
    If I need to do a generic cable for manufacturing purposes I do it separately but the generic cable once labeled is now unique. So in my BID/WID schematic every connector ref des. is unique. Just my approach. In my BID I will use the parameter <harness> for the generic cable name or designation.
    jef
    Hi Zak, we approached this in the same manner. If using the same
    harness numerous times within the same interconnect we would use –ASSY-1 and
    then use a Tokenizer or the slice function, (e.g. W123J1-ASSY-1,
    W123J1-ASSY-2). With the Tokenizer or slice function the label would read
    W123J1 and satisfying label requirements and the reports would read the full
    name W123J1-ASSY-1 with the understanding that the –ASSY-1 represented
    assembly one. This keeps the quantities correct and satisfies the unique id
    requirements of Creo.
    The slice function seems to be the easiest for everyone to use
    rather than remembering how to write the Tokenizer.
    If we have a interconnect in which we use only P1 and J1 as
    labels we follow the same method by incorporating the harness number first and
    using a Tokenizer or slice command. If within the same interconnect you have
    multiple uses of the same harness then we add the ASSY-1, ASSY-2, etc… or
    P1-W123-ASSY-1, P1-W123-ASSY-2.
    Once again the slice function works best.
