I have a small class project. A number of students have bright blue lines shown on parts, but I do not. We're all in Creo +. The lines don't appear in the part view, just the assembly. They aren't visible sketches, and I've tried hiding all the different layers and I can't make them go away.
If these are appearing when activating the Live Simulation tab, it is an indicator of a Creo Simulation Live Bonded Interface.
To remove these lines, deselect the Simulation Objects Display button in the Live Simulation Tab.
You can find these specific interfaces in the Live Simulation Tree, under the Analysis Name > Contacts > Bonded node. The icons in @kleipold’s image look like they are Bonded. There could also be No Separation or Free nodes
Here’s an image for reference. The model geometry is hidden to better display the interfaces and icons. (Also surfaces were the same blue color and was difficult to see.
Relevant config.pro options are simlive_contact_detect_inactive and simlive_contact_detect_on_study.
Let me know if there’s any other questions about the contact display.
Nothing really odd about it - but when I opened it today - everything looked normal. I'm not sure what changed. I'll ask the class if they are still seeing similar issues.
They could be from the internal sketches used in the part features. There may be a config option that isn't set to hide internal sketches. You could create a layer and add them to it.
Mike
Windchill Satisfaction Survey
Help shape the future of Windchill. Take our 5-minute survey and share your feedback.
