BOM表如何只显示简单表示的部分
一个组件生成的BOM表,但是有些部件不希望在BOM中看到,就使用了简化表示,现在只有在3D装配图形中看不到零件了,但是生成的BOM中还是存在不希望看到的零件,我应该如何设置才能达到想要的效果,感谢
    You need to remove your existing BOM if it was created for the master rep and not the simp rep.  They don't auto update when switching between reps
    Go to Table > Repeat Region > Model/Rep from the menu. Then select the table and choose the table you want to display in the BOM (Bill of Materials) table.
    kdirth
    You can use Repeat Region Filters to remove unwanted items from the BOM.
    Select Repeat Region > Filters then the BOM Table. Select By Item then select the items that you want to remove (Hold Ctrl to select multiple items)and select OK then Done and Done/Return.
