2-Explorer
Jun 19, 2015 3:54 AM UTC
BOM Balloons with Custom Symbol
Is there a specific setting into configuration or somewhere else which will not allow to have BOM balloons with custom symbol?
Regards
Ketan
Jun 19, 2015 5:35 AM UTC
Ketan,
if you want to use custom BOM balloon symbol, you have to:
  1. place the symbol into the drawing - Creo puts symbol definition into drawing file
  2. remove the symbol from the drawing  - symbol definition remains in drawing file
  3. show BOM balloons using custom symbol
Martin Hanak
2-Explorer
Jun 19, 2015 5:41 AM UTC
Martin,
I am doing all above steps. It is working for creo 2.0  M090 and M120 I have with me. Custom symbol I created using M090.
What challenge I am facing is that same thing is not working on our client's machine [Creo 2.0 with M120]. I am wondering why it is not working on their system.
Regards
Ketan
Jun 19, 2015 7:11 AM UTC
Ketan,
create new empty drawing and execute steps 1. and 2. in it (do not execute step 3.). Send this drawing to client machine and test custom balloon functionality.
Martin Hanak
2-Explorer
Jun 19, 2015 6:04 AM UTC
l have found:
bom_format --- Sets the BOM format file to be used for a customized BOM. Specify name and path.
DEFAULT VALUE:
<creo2.0_loadpoint>\text\format.bft
<creo3.0_loadpoint>\text\format.bft
Maybe they are using this config option in config.SUP? Just an idea...
2-Explorer
Jun 19, 2015 6:11 AM UTC
Hi Milan,
Thanks a lot for this information.
I am using custom BOM from a file [Table->Table From File] and same is working fine irrespective of BOM_FORMAT.
I am setting property of BOM table as BOM Balloons -> Type as Custom symbol.
Could you please explain me that above need to be changed or not in order to have customized Balloon symbols.
2-Explorer
Jun 19, 2015 6:23 AM UTC
Ouch... it is my mistake.
bom_format has no connection to your problem.
l´m sorry about confusing answer!
