BOM count is wrong
We have an assembly that has 16 hex nuts in it. 12 are in a pattern of a group with a bolt and 2 washers. Windchill structure of the assembly shows the full counts. In the Creo BOM table, one of the groups is not being counted. I checked for repeat region relations and there are none.
Has anyone seen this behavior before? If so, how did you fix it?
Creo 4 m080
Windchill 11.0 m030
kdirth
BenLoosli23-Emerald IIIAuthor
Nothing was added to the BOM with the repeat region table settings.
It seems to be the first instance of a group that was then patterned to get the 12 locations.
The group consists of a cap screw, 2 washers and a nut.
StephenW
There's no normal reason this wouldn't work.
Things I would look for or try:
1. Is anything "flexible"? this screws up BOM tables.
2. Put an new table on the drawing and see if it is something funny about the table
3. Any pattern failures, reference patterns or such sometime don't recreate right after redefine.
4. Delete the pattern and re-create.
5. try to re-create the problem on a new assy/drawing (last ditch effort to see if it's me or a glitch or a bug)
