Oct 20, 2026 6:14 PM UTC
BOM Max repeat region
This is only a little annoying and I’m on Creo 8 right now, maybe this has been patched out. But has anyone else hit a limit for repeat regions in a BOM? I have it refusing to fill out the 12th repeat region and just has the first cell filled out with the parameter and session ID of the assembly. ex: &asm.mbr.material_spec2:195
If there is a fix let me know. I have so many columns so I can edit single lines in notes so half the BOM is off paper.
Oct 27, 2026 9:19 AM UTC
A screenshot would help in understanding. However, from what I understood, check the attributes of the repeat region and set as per the picture.
If you are new to Creo or to BOM Repeat Region, I would highly recommend that you study the help section on repeat region. It is vast and would help.
Knowing, what we know is just a fistful of Earth, brings in humility.
