BOM Table problems
  • September 22, 2011
  • 2 replies
  • 705 views
I have an assembly drawing in which I show a BOM table and associated BOM
Balloons.
When I select the sub-assemblies to make them flat, they all behave as
expected except one sub-assembly. This particular one stays as it is and I
see an error message:
'This part has no associated data. The action cannot be performed.'
In addition, I am unable to show a BOM Balloon for this sub-assembly. If I
show all BOM Balloons, I get them all except that one.
It is a conventional enough sub-assembly, with a number of solid components.
Any ideas what may be the problem?
WF2, M220
John
Is it possible that the problem sub-assembly may not have any BOM
parameters to show?
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
It might have some BOM parameters, but the problem could be caused by not having all the required parameters referenced by the repeat region. Be sure to look at the repeat region relations to see if the relations are looking at parameters that are not displayed in the table. Not having those could cause a problem.
David Haigh
