BSPT Pipe Thread Programming in Creo Parametric
Anyone try to define a BSP or BSPT thread in Creo? Do we try custom tools or maybe define it as a tapered mill? Even without any check surfaces the tap I defined will not go past the start surface.
2-Explorer
There probably is no specific drilling or milling sequence for tapered threads.
If you use a drilling sequence, you may use a customized cycle to define what is needed for the machine
When using a milling sequence, you could probably use trajectory milling, but you will have to design the curve (as drive surface cut again only allows verticval surfaces, i.e. no taper angle)
is there any progress on this topic?
