Cabling - Auto-populated wire run list
I have been doing battle with Pro/Cabling and have now run out of steam.
I have managed to define a couple of connectors, complete with entry ports and pin numbers, created a network and autorouted my cable using the NWF file as recommended.
So far, so good.
I have created a flat harness drawing, with conductor lengths, etc., but I now want to create a wire run list.
I have so far failed to manage this part of the job. I have a repeat region showing one of the connectors and its entry port names together with the wire names attached to each of those entry ports. I cannot get the table to pick up the 'TO' connector/pins, or to read the colour information from the spool definitions included in the NWF file.
I would appreciate any help you are able to offer.
WF4 (!) M220
John
